110V Motor limiter
nathanmueller
Joined May 23, 2019
I have a 110V vacuum motor that regularly runs at 9 amps. At startup, it surges close to 10 amps and then comes back down and runs between 8.8 amps and 9.2 amps.
What can I put in line to limit the draw of the motor to 9 amps?
I don't want to have to add a circuit board, is there anything that can go in the line?
All suggestions appreciated
BTW, I'm no electricity guru, that's why I am on here
MaxHeadRoom
Joined Jul 18, 2013
30,784
Is this a AC Universal motor (brushes)?
There is a Triac controller, but this would mean adding a circuit board.
A simple SPDT centre off toggle switch that places a 10watt resistor in series for start up in one position, the other would be run position.
Max.
