100X frequency multiplier
dante_clericuzzio
Joined Mar 28, 2016
246
That's the way a PLL works.
Two divide by 10 counters cascaded gives 100X.
Ok if that's the only way i will try although it could be tedious work...but i am just wondering like the modem-router that i opened up the circuit looks very minimal and probably using 1 IC with plenty of pins to do that -- I am just guessing
dante_clericuzzio
Joined Mar 28, 2016
246
I don't understand it being tedious.
It is not 100 more chips, just another one.
You meant 1 to 10 then 10 to 100? that's logical ....i though it would like another combination of each circuit my thought was 10 + 10 + 10 + 10 + 10 + 10 + 10 + 10 + 10 + 10 so it's 10 circuits of the same kind.
Now that you are saying 1 to 10 then using another chip to multiple this to 100 that would be 3 chip ...now i got it
dante_clericuzzio
Joined Mar 28, 2016
246
I built an RF synthesizer years ago using some of these...
https://assets.nexperia.com/documents/data-sheet/74HC_HCT193.pdf
If you put a few of these in series and then preset the count on each timeout, you can have divide by lots :)
Would you be kind to share working schematic that generate up to 2.6 Ghz frequency? hehe
and by the way when you are saying this
"Adding another 7490 divide by 10 is no big deal." --- why do you mention divide when we want to multiply i am just curious there must be a reason
dendad
Joined Feb 20, 2016
4,639
You are actually dividing the "feedback" signal to the Phase Comparator. It generates a signal to move the Voltage Controlled Oscillator (VCO) so a sample from the VCO matches the reference frequency. So if the VCO sample frequency is divided by 2, the VCO is driven to twice the reference frequ. Likewise, if the VCO sample frequency is divided by 100, the VCO is driven to 100 x the reference frequency.
And yes, this is how a lot of circuits generate the 2.6Ghz frequencies.
often with mixers, tuned frequency multipliers and PLLs.
