0-99 Counter with J-K Flip Flop 74LS107A
eetech00
Joined Jun 8, 2013
4,744
Hi, I need to simulate on a virtual breaboard a 0-99 counter. I need to build it using a 7 segment led display, 74LS47 decoder and a 74LS107A JK flip flop.
I allready build it but doesnt work at all.
I would thanks a lot any help and advice.
https://drive.google.com/file/d/1CknBidqndFYUbM9RIbkduGF7dfmv19UK/view This is the program Im using right now.
Post a schematic so we don't have to figure out your wiring.
You'll get quicker help that way...
Polipker
Joined May 11, 2022
9
Hi. I followed these schematic below, with different TTL but still JK flip flop so I touhgt it would still work. Ill post here everything I used.
Thanx for yor answers!
35,268
Welcome to AAC!
There are some inconsistencies. In your protoboard layout. I see 74LS47 and no 555-timer circuit.
In your circuit diagram I see CD4511.
I don't see any connections to pins 3, 4, 5 on the 74LS47. Make sure LAMP TEST input on pin-3 is at Vcc.
There are simple signal tracing you can do on your own. Use a 1kΩ resistor in series with an LED and use this as a signal probe.
Start with tracing the 555-timer clock signal at a low frequency of about 1Hz.
Trace the signal to your flip-flop and the DCBA inputs of the 74LS47.
Buena suerte!
Polipker
Joined May 11, 2022
9
Welcome to AAC!
Buena suerte!
Hi thanks for answering! The diagram with CD4511 its not mine. Its the One I used yo figure it out how to do It. Also the program I have ti use its limited and doesnt have any kind of resistor. I'll check out the rest thanks!
35,268
Can you test this with a real circuit?
35,268
On your first 74LS107 stage what is the CLOCK input?
Does your simulator have some kind of square wave function generator?
