0-40V Voltage Boost from 0-20V
clmoi90
Joined Mar 29, 2018
13
Hi everyone,
I am working for a company which builds test bench. We have our own standard products but I have a specific need for a project.
I need to have a 0-40V output voltage whereas our product can only provide 0-20V output.
First I would like to say I don't have any experience in PCB design even though I have some basic knowledge.
To be more accurate I need to have 26 channels of 0-40V with at least 10mA max output (no real requirement in term of accuracy). In my system I have more than 60 channels of 0-20V, 14mA max (common ground for all channels).
I see 4 possibilities:
1) Use a Boost converter, but I guess if I double the voltage I will divide the current by 2 (which is not ok since I need 10mA).
2) Use somehow two 0-20V channels to get one 0-40V channel.
3) Use a OPA with gain 2. But it means I need to add a 0-40V PSU in my system for Vs+/Vs- of the OPA (the bench only has 24V PSU). This could be ok but if I have another easier solution that would be great.
4) To buy a board which can already do what I need but I didn't find anything yet (I am also limited by the space, I would say: 25cm*20cm*10cm).
Anyone with good experience could advice me about which direction to take?
Or maybe anyone knows such a 0-40V boost board already existing on the market?
Thank you in advance!
Ludovic
wayneh
Joined Sep 9, 2010
18,108
I'm working right now on a circuit that employs a voltage doubler. I think it would be capable of 10mA but not with great efficiency. It probably would need at least 40mA input, I really don't know. A DC-DC converter would do better. I'll post it here if you're interested.
Norfindel
Joined Mar 6, 2008
326
What do you exactly mean with "channels"? Are they floating, like in a lab PSU? If that's so, then you should be able to connect two channels in series, right?
clmoi90
Joined Mar 29, 2018
13
Thank you all for your comments!
@MrChips
We are using 24V PSU (350W) which is outside of the PCB, and two votage regulators on the PCB (24V=>5V and 24V=> +/-24V) to power the OPAs and other components.
I can't change this 24V PSU since all our system is designed with this 24V PSU, but if it's really needed I could add another 40V PSU to my system to power this "0-40V Boost Voltage Board" and then use OPA with a gain of 2. Each OPA would take one of my 0-20V channel as input and output 0-40V. Do you think it's the best solution? Since I have a common ground on my 0-20V PCB, it means all these gain 2 OPA will have a common minus, I don't know if it can bring issues.
@wayneh
Ok so it seems it's not that easy to use a voltage doubler. I am far to be able to have 40mA as input :/
@Norfindel
These 60 channels have the same ground so it's not floating same as in PSU lab. So I cannot directly connect two channel in series to get 40V. Except if there are some tricks which I am not aware of.
I am not sure I have been clear but my PCB have 60 channels which are controlled by our SW with a range of 0-20V and I need to have a range of 0-40V for a specific project.
Norfindel
Joined Mar 6, 2008
326
Only safe way i can think of, is an external 40v PSU with opamps with gain 2. If the opamps can't go to the + rail, the PSU will need to be of a slightly higher voltage (whatever the opamp needs). And make sure that the opamp can supply the output current needed and can work with such a large supply voltage. Remember to use decoupling capacitors on every IC.
