Can anyone get me Datasheet of STR G5643D or power circuit designed with this IC?.I need it to repair Compaq MV7540e monitor.If anyone has the schematics of this monitor kindly send me.
Allegro Microsemi has a number of parts (voltage regulators) with the STR- prefix. From what I understand, they're made by Sanken of Japan.
I think what you'll find is the regulator in question is a proprietary design for Compaq, and Allegro won't give you a datasheet for it. Compaq does this to make their designs harder to reverse-engineer, but it sure is a pain when you're trying to fix stuff you paid for.
I'd almost bet it's a 5V regulator with external feedback pins and yes, it was made by Sanken. A bit away from what they usually make but I'd drop them a line and go through all the BS until you can actually talk to an engineer is willing to talk about it and pull up old documentation.
The problem with oddball ICs is that most of the few places that have them don't want to ship in a qty of one unless you can talk them into sampling one to you. Quite honestly, if you've got a schematic, a common 3 pin will do the same job. You also need to figure out why it blew up in the first place.
