CurSns3 – High-Side Current Shunt Test.
Blog Index.
This section, CurSns3, will test a High-Side Current Shunt to demonstrate:
High common mode voltage
Big (massive) error using 2-wire connection
Why you should use 4-wire connection whenever possible
The advantages of isolation amplifiers...
Blog Index.
This section, CurSns2, will cover Current Sense Resistors (RSense) in different circuit configurations:
Low-Side
High-Side
2-Wire
4-Wire
A current sensor is used to convert current to an easily measured voltage that is proportional to current. There are a wide variety of sensors...
CurSns1. Current Sensor Introduction.
Blog Index.
Voltage and current sensing are fundamental to electrical and electronic circuits. Pretty much all analogue parametric sensors have a voltage output that is going to be compatible with the input of some measuring device, for example an ADC or...
Blog Index.
This blog, CurSns4, will look into:
· Current Shunt Amplifiers
· Differential amplifier, common mode limit
· Isolation amplifier
Current sensor resistors are used to convert current to an easily measured voltage that is proportional to current as discussed in the blog...
