Can someone please help explain how to determine the appropriate wattage for zener diodes, specifically for the circuit below? Input voltage is 5.0v dc and I'm trying to limit current to ~25mA max so what should the wattage be for the zener diode? Also - If I was trying to limit current in a 5.0v dc circuit to 150mA with a 33ohm resistor, what should the wattage be for the ZD?
