- Joined Jan 23, 2018
- 28,485
OK, I did make two assumptions, first being that the buzzer is to alert a human with normal response times and second that the frequency is at least 500Hz. Then with a reasonably small capacitor , 0.1mFd, the voltage variation will not be so big. And the one electronic buzzer that I put into a piece of equipment used a CD4049 with a one-inverter oscillator, one stage phase inverter, and two groups of two inverters in parallel driving a magnetic speaker in push-pull, it would work from about 3 volts up to 15 volts, with almost 2 Vdd driving the load. Noismakers should be able to tolerate wide variations of supply voltage.A shunt capacitor might well do the trick. Certainly worth a try. It will also delay the on and off action by a bit, but if that's tolerable and it can stabilize the voltage sufficiently, then that's good enough.
