yup... even considering their price, they seem to be a far better choice than a zenerI dumped my collection of Zeners, and replaced them with a bunch of TL431s. It is useful for much more than just a shunt regulator...
Wow. That really dates me! Forty-two years ago I was cashing a paycheck as an analog designer.and that's as close to zero as we could get from a standard zener in 1973.
And I was a 9 year-old kid just beginning to feel the itch for electronics (and disassembling things)...Wow. That really dates me! Forty-two years ago I was cashing a paycheck as an analog designer.
Sometimes it doesn't - the zeners can be grouped as either PTC or NTC, the break even point is somewhere around 5.6V.I've always thought that zeners were terrible as voltage references due to their temperature drift sensitivity. How come a zener and an ordinary 1N400x in series tend to cancel their temp drift?
The old standard was a 5.6V zener providing the reference for an emitter follower series pass transistor - you lose about 0.6 - 0.7V ish on the B/E junction, so it comes out at pretty close to 5.0V.If i want a 5V regulated output from a Zener diode from a VS of 12V , how do i calculate it ?
I assume i have to drop 7V on the series resistor to have 5V on the zener. But if the breakdown voltage of my zener is 5.6 then this will not be sufficient, correct ?
- Do i have to put a Zener diode of 4,7 breakdown voltage then ?
- Is the zener breakdown region available in any voltage range (untill it reaches it's limit) For example if i put 8 V on a Zener of 5,6 breakdown will it also have the self regulating function but then on 8 Volts ?
Thx Mike
by Jeff Child
