- Joined Jan 23, 2018
- 28,486
First: My comment about reflowing connections was for a "thru-hole" PCB. Surface mount is much different. My suggestion now is to use signal tracing. Add a test point, relative to common, to the junction of R13 and R14. That will allow learning in which segment the problem lies. Some times signal tracing is the only way to locate a fault.
