XP Experts needed
MaxHeadRoom
Joined Jul 18, 2013
30,654
I recently got rid of a virus in my XP PC I use for general purpose.
Now I cannot run any program from the desktop icons, or else where, I get the Properties window instead, also the mouse looks like it does multiple clicks, Changed the mouse and the same thing.
Any ideas.
Max.
joeyd999
Joined Jun 6, 2011
6,279
Any ideas.
Max.
Wipe and reinstall. Really.
As an alternative: Install Linux as the base operating system. Then, install Windows under VirtualBox.
You can then make "snapshots" of the Windows install which you can revert to when trouble arises.
I know I'm gonna get crap for this comment -- especially from @#12 -- but it really is the only sane, trouble free way, to use Windows, IMHO.
Raymond Genovese
Joined Mar 5, 2016
1,653
Any ideas.
Max.
So, no pre-virus restore point available? No backup?
Try:
Clicking shortcuts on desktop only brings up properties box?
or maybe even
Desktop icons & start menu tools wont work!!!
If those (and probably 20 other possibilities) don't work, go here and create a new entry called "The Reinstall Blues".
dl324
Joined Mar 30, 2015
18,326
That reminds me that I need to make an new image of my OS disk so I'll have the last security patch Microsoft issued if I have to restore from backup...
MrSoftware
Joined Oct 29, 2013
2,273
As someone who has been on the software side of things for a long time, my advice is retire the XP system and move to something more modern, at least Windows 7, preferably Windows 10, for security reasons. The Windows XP design is so old that there is no way to make it reasonably safe against modern threats, except to unplug it from the internet entirely.
Keep good backups, something like Symantec or Acronis. Set the schedule to backup at least once a day. Now if you get a horrible virus, then in a worst case you just restore the system to your last backup, which would have been earlier that day or in a worst case the day before. You can keep the backups on an external hard disk, or in the cloud if your internet connection is fast enough to make this reasonable.
As far as running Windows in a virtual machine; that is one possible solution, but there are some tradeoffs. Primairily you are giving up some performance due to the virtualization overhead, plus hardware support can become an issue since there is an extra layer between the OS and the hardware.
At the end of the day, there is no alternative to backups, both on-site and off-site.
MaxHeadRoom
Joined Jul 18, 2013
30,654
I do have an Acronis back up, I was hoping there would be a simpler fix before going ahead.
I have a laptop with win10, but I have alot of programs that run under XP.
Max.
MrSoftware
Joined Oct 29, 2013
2,273
It's always tough when older required programs don't run in newer OS's. This is a good case for virtualization. Going forward, install VMWare or something similar on your Win10 machine, and install XP as a virtual machine, then use that to run your older programs.
If it were me personally, and if the budget allows; buy a new hard disk and restore a known good backup to the NEW disk. Then copy your latest data over from the old disk. This way you've still got the old disk around should you need to extract any more data.
ian field
Joined Oct 27, 2012
6,536
Any ideas.
Max.
Any virus worth its salt will let you think you've won so it can carry on mischief in the background.
Re install the system on a cleansed HDD from a known clean OS install disk.
Wherever possible; I use an older smaller drive just for the OS. If anything nasty happens - I can do battle with that with all the drive containing my data, unplugged.
A couple of years ago; my boot HDD caught something nasty that no antivirus or partition wipe would shift. Deleting all partitions and installing Linux to over write everything finally did the trick.
bertus
Joined Apr 5, 2008
22,921
Couldn't you find the "any key"?
I quit using windows when there was a virus hose for windows 98SE.
I am quite happy with linux now.
Bertus
