XL6009 boost converter doesn't work when I replace the multi-turn pot with a volume resistor of the same value
beginner99
Joined Oct 17, 2024
10
Hi
I want to replace the multi-turn pot on the circuit board with a volume resistor for easier control of the output voltage, but when I do so, the IC starts heating and the output voltage is almost the same as the input voltage, and when I solder the original pot back in place it starts working again, what is the issue here and how do I solve it?1WYHf.jpg
28,488
It seems likely that the TS has not measured the value of the resistor. And it is even more likely that the actual connection is not quite like the original circuit.
In addition, this is a switch-mode supply and probably lead dress matters quite a bit.
