XL6005 Dimming fuction
Was the question clear?
  • Yes, I got it
    Votes: 0 0.0%
  • No, provide more info and links
    Votes: 0 0.0%
  • You should search the answer by your own
    Votes: 0 0.0%
  • Total voters
Dan Aronin
Joined Dec 14, 2018
37
HI all, I want to understand the proper way to make a dimming function for the XL6005.
I found some schemes that suggest using the EN Pin:
And some that use the FB Pin:
So which one should do the work and what PWM signal should I use?
sstech General Electronics Chat 4
Similar threads
Led Dimming using Mosfet
