Wrong figure & equation in Magnetic units of measurement
jonahugh
Joined Oct 23, 2012
2
In the section on
I noticed that there is an illustration relating to capacitance and equation for dielectric calculations. This is just underneath SI units.
Although there may be some specific reason for this, I am a little confused by it, since the sentence after the illustration refers to "micro" which is not included in the illustration.
tshuck
Joined Oct 18, 2012
3,534
I believe I am going to have to side with jonahugh on this one.
You are correct that this is a diagram pertaining to a capacitor, however, it has no place in the chapter titled, "Magnetic units of measurement", considering it pertains to the electric field as opposed to the magnetic field.
Additionally, the following sentence references a μ that has not been defined, or even seen!
I believe this is a case of simply uploading the wrong image....
Also, the image can be seen again(and rightfully so) in Volume 5, chapter 1, page 5.
Dcrunkilton
Joined Jul 31, 2004
422
This is a link to the correct image:
http://openbookproject.net/electricCircuits/DC/10233.png
Note that the image number at openbook project (ibiblio.org) is the same as the number of the incorrect image at AAC
This is related to me re-using some not available image numbers. There were several images affected. I cleared it up at ibiblio some time ago. At least, I think I cleared it up at ibiblio.
To fix this jrap or somebody needs to download the above image from ibiblio to aac.
Considering that there were several bad images when I fixed it at ibiblio, reloading all the images might be warranted.
This might be the only way to get the images that we have made changes to recently-- unrelated to this thread
Dennis crunkilton.
