My dad gave me is Dewalt Powershop 7770 bench saw and it was working great at his place wired on 240Vac. I had it modified for 120Vac but since then, it never really worked correctly. It will start without the blade, but if I attach the blade on the shaft, it will not be able to pickup enough speed from the 0.5sec Start Winding to keep running on the Run Winding. By looking at the wiring diagram on the plate, it does not make any sense with the actual wire color coming out of the motor. By looking at the 120V diagram below, what are the 2 shapes where the Red, black violet and Blue yellow are connected?
thank you
Rickydou
thank you
Rickydou
