Wireless headset base transmitter bad voltage regulator
Irving
Joined Jan 30, 2016
5,138
That's similar to mine. Not hugely accurate but good enough to ID a part against standard value lists. Useful to have around, I always check SMD parts with one as can never be sure they've not got mixed up in box. Go for it...
Bwachtel
Joined Jul 8, 2020
26
LOL well that's good because I ordered it 2 hours ago lol. Thanks again for all of the help! If you don't mind, I'll have more questions. I'll post back after I measure the inductance.
Bwachtel
Joined Jul 8, 2020
26
OK I got the results. Appears to be 4.9uH.i did not remove the voltage regulator since it is already creating an open circuit.
Bwachtel
Joined Jul 8, 2020
26
This is a 100uH to show the accuracy of the meter. One is with the test leads and the other is using the pin socket on the meter. 20200713_195701.jpg20200713_195814.jpg
Bwachtel
Joined Jul 8, 2020
26
Also I think this capacitor is bad. I beleive it is supposed to be a 100uF capacitor. What are you thoughts? I attached two other capacitor readings that should be 100uF as well and they measure pretty close to that. Screenshot_20200713-200442_Photos.jpgScreenshot_20200713-200456_Photos.jpgScreenshot_20200713-200514_Photos.jpg
Irving
Joined Jan 30, 2016
5,138
Excellent!
On the face of it that cap does appear to be bad. Which one is it? How sure are you that the reading isn't being affected by the components around it?
Bwachtel
Joined Jul 8, 2020
26
Excellent!
I can't be positive that I'm not reading another value for the capacitance without removing it from the board. By that point though, I might as well replace it regardless after I remove it.
Could that cap be the culprit for why the voltage regulator failed?
Was that inductance value able to help you determine what voltage regulator I should use to replace the bad one?
Irving
Joined Jan 30, 2016
5,138
It will help, but it's 4am here :) and I have a busy schedule today so I'll look into it as soon as I have a few min to spare.
It's quite possible that was the culprit. If you can, trace out which power line its on.
Bwachtel
Joined Jul 8, 2020
26
Oh by no means was I expecting an answer right now! Was actually surprised to see you reply this late. I am just really appreciated for any help and thank you again for taking so much time to help me with this!
Thank you again!
Bwachtel
Joined Jul 8, 2020
26
C92 is measuring the same as C94 at about 377uF. It makes me beleive im measuring something else in the circuit.
Irving
Joined Jan 30, 2016
5,138
hmm, yes.. I was hoping it would be 10uF
Its across 3.3v Vout to ground, so C92 and C94 are in parallel so should add together, but 377u sounds high. Maybe remove C94 and check again?
Anyway the replacement chip, I am fairly sure, is this Torex manufactured one from Mouser . Its the only family of similar chips that use 4.7uH inductors, everyone else uses 1, 2.2 or 10uH.
Edit:Fixed link
Bwachtel
Joined Jul 8, 2020
26
Awsome, thank you so much! I might try and remove that cap. I'll let you know if I do. Otherwise, hopefully this regulator does the job.
Bwachtel
Joined Jul 8, 2020
26
Edit:Fixed link
Good news! It's working! Had some issues at first because I didn't do a good Job of saldering the new smd chip. But I went back over it 2 or 3 times and now I have a good connection.
Couldn't attach the. Mp4 file so here is a link to it of the board working. Video of board working.
I thought about testing the voltages but I don't want to risk ruining something.
Bwachtel
Joined Jul 8, 2020
26
I forgot I had the test points on back. Here is the 3.3v and 1.8v test point measurements. Looks good enough to me! 20200717_134802.jpg20200717_134745.jpg
Bwachtel
Joined Jul 8, 2020
26
You're welcome. Lets hope it stays working, we never got to bottom of why it failed exactly...
Before I remembered that it used a USB port for power, I found a connector that was 5v and 2a out. I used that figuring it would work. Maybe too much current fried it? I can't imagine 2a was out of its limits?
I don't know. It works currently so I'm just going to stay blissfully ignorant lol.
