Please anyone expalin me about these circuits....Why these diodes are used and how does this circuit work
Transistors should work. When one transistor is turned on,
the second transistor must be closed.
This function is performed by diodes.
When one transistor is open at drain low voltage
and it is passed to the shutter the second transistor.
This second transistor because this will have a small gate voltage
(less than the threshold voltage).
Then the transistors are reversed.
Voltage fluctuations occur due to the presence of the oscillatory circuit (LC).
