Hunt around for some Augat wire-wrap prototyping boards.
Follow up from my post #20:When you are wiring multiple buses such as encountered in microcontroller experimentation, breadboarding becomes painful.
There are three options (almost all obsolete) that I have used successfully in the past.
1) wire-wrapping, if you can locate wire-wrap DIP sockets
2) Scotch-3M IDC breadboarding system (I have to look up the correct terminology) - which is probably impossible to source. This, by far, is the most efficient breadboarding technique. You simple run wire-wrap wire to each connection point and press it in. It allows you to lay continuous runs of a signal wire.
3) Using special wire insulated with a thermo-plastic coating. You simply wire from point-to-point using your soldering iron. The heat from the soldering iron melts the plastic coating and solders the end of the wire to the solder pad. As above, you can lay continuous runs of one signal without having to cut the wire.
For that price, you'll be getting counterfeit parts. If you're lucky, they might work (sort of).getting 10 for $15 on aliexpress
Sayal sucks...I got 2 eeproms AT28c256 for I think $25 or $35 each...getting 10 for $15 on aliexpress
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 17 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 22 | |
wire wrap pins | Marketplace | 10 |
