Window Comparator "Glitches"
35,235
If we can assume that the pulse amplitude is not changing drastically from one pulse to the next, then a simple low pass filter with the appropriate time constant should be sufficient in lieu of the peak detect circuit.
WBahn
Joined Mar 31, 2012
33,263
Definitely worth consideration. A lot of devils are in the details on that, though. Are the pulses tightly related, or largely independent? What is the purpose of detecting pulses that fall within that window and how accurate does the detection have to be and on what scale? But those are now questions that can be put to the customer that might not have ever been thought about previously.
28,434
First, the LM311 is not a regular comparator, it has an output transistor with both the collector and emitter open, and it also has an input bias adjustment connection. So it is highly flexible. A scheme providing the different output signals can be provided by multiple comparators and some digital logic. An LM339 quad comparator would be simpler to apply and require less board space.
WBahn
Joined Mar 31, 2012
33,263
Given that the response time of the LM339 can be over a microsecond, I'm not sure how well it can be relied on to work with pulses that last only half a microsecond.
35,235
Wish we knew the actual application of this window detection circuit.
If you can average the peak voltage over say five pulse duration, then yes, a slower comparator (5 μs response) would be appropriate.
WBahn
Joined Mar 31, 2012
33,263
The slow response is for small signals. The large signal response time is much faster.
For TTL level signals it's only 300 ns. That's not much margin. Plus, there will be signals that only rise above the threshold by a small amount, which interacts with the question of how accurate the threshold values need to be and how long the output pulses need to be.
