You can take it from pin 8 on the CD4503, the shield on the printer connector, the shield on the USB connector, pin 16 of the ZIF socket, ...stupid question, from were can i take the ground in order to measure.
Enter the Test H/W tab, click on the OE, D0, and D4 pins on the picture of the ZIF socket.ok i found it 5.42v
Power off the programmer and swap the two chips to see if the problem moves with the chip.I mesured 3.20 v on pin 3 of the first cd4503, the other cd 4503 has 0v on pin 3
Yes.I ve got a d4503 from NEC
Do you thank u can replaced it?
Replace the original chip and set all data lines HIGH. Measure pins 3,5,7,9 of both CD4503. All pins should be HIGH.I swapped the other 4503 same thing.
In the Test H/W page, click on the D0-.D7 button as you did before. Measure the voltages for the data lines on the ZIF socket. For any that aren't HIGH, measure the corresponding pin on the CD4503.How to set all data high ?
What changed? Earlier you said you measured 0V on all pins.Ok i selected do->d7 i measured 4.75v on all zif pins.
upditerm - working serial coms using only the UPDI pin on AVR including ATttiny using cheapo SerialUPDI programmer. | Microcontrollers | 0 |
