Willem Programmer ERROR
Schnuffi0
Joined Nov 7, 2024
7
Thanks, I will try this, but this needes some time. It is strange, because other Circuits like PIC can be read an programed without any problems.. But I caln try to find an XP PC with built-in LPT?
Bye, Mario
WareZ
Joined Jan 7, 2024
31
Bye, Mario
Yes, there must be people who sell old computers.
idk why not working with adaptator I think the system is not suitable to be converted with the adapter
Schnuffi0
Joined Nov 7, 2024
7
ok, I use an Pc with integrated( on board LPT1). same result. verify alway fails and checksum is also different each time, I read the Chip. Strange. I attach two Pictures, with one of my Willem HW, I use. The 2nd one has same problem.IMG_4666.jpegIMG_4666.jpeg
Schnuffi0
Joined Nov 7, 2024
7
Thanks, I use the TSOP 48 Adapter and I removed it from the ZIF-socket only for picture, in order to see the Pins and Jumper-settings. AM29W800(bottom) it the Chip, I‘lo try to read and copy, if it works.can attach a file, I eead fron the chip.. Maybe someone can see, what‘s wrong and where the read-out is twice..
Mario
WareZ
Joined Jan 7, 2024
31
ok, I use an Pc with integrated( on board LPT1). same result. verify alway fails and checksum is also different each time, I read the Chip. Strange. I attach two Pictures, with one of my Willem HW, I use. The 2nd one has same problem.View attachment 335421View attachment 335421
Here is mine, looks like the same ones.
I used only the PLCC32 with willem software
Did you put the blue pins correctly?
