Willem 5.0 Eprom Programmer #2
MakeinRepairs
Joined Feb 26, 2022
View attachment 87677 Well, after doing some more digging, it turns that the device is not so bad.
It's an improved version that should take care of all the voltage problems. I have found that there are some jumpers on the PBC for this.
In the picture, the yellow square jumpers are used for modifying the VPP. So With the trimmer I can fine-tune it, at 12.5V. And by changing the position of the jumpers, the VPP becomes 21.5 or 25V. And it stays there, there is no VPP drop. I have been able to write yesterday some old 2716 (KR573RF5 is the code) Soviet Union chips at 21.5V.
Only one I could not write, a 27128, no matter what I have tried. But I think that one is broken.
And for VCC, there is the jumper with the pink square. And I can provide three VCCs from there (5V, 5.5 and 6.2)
---I have the same programer and I too was trying to adj v and I endedup threw my own fault burning out a few of the ics next to the db25 connector - I removed them to test and order not thinking that there were no IC numbers or paper wk that I can find to put the correct ones back - can you zoom in on your pic for me so I can read the IC numbers and put my replacement chips back in the correct places , thanks
Moderator edit: New thread created from old thread.
dl324
Joined Mar 30, 2015
18,467
Welcome to AAC!
Here's a picture of a 5.0 from Sivava.com:
The two IC's closest to the DB-25 connector look to be CD4503. Do you have a schematic and the ability to trace components on your board?
Post a well-focused picture of your board and I'll see if it is close to any board I have. Sivava made some changes to how data is read to give the speedup in the 4.5 and later boards, but most of the logic is the same as PCB3.
EDIT: Better picture of Kee 5.0 board:
