Hello again,I don't know about newer systems, since I don't own newer cars (and likely never will), but I've done lots of tests on stopping distance in each of our vehicles (except my wife's 2014 Mini Cooper as I haven't had the opportunity -- and may never get much of one since it has such low ground clearance that the range of road conditions around where that fall between "slick" and "high-centering" is pretty narrow) and I can always stop it quicker than the ABS systems did, despite having to contend with tricking them since I couldn't turn them off, while still maintaining control. On the mountain, it was even more pronounced. On several occasions the ABS system simply couldn't stop the vehicle, while (except one time) I could if I either pumped the brakes just shy of the ABS kicking in, or applied them very gingerly, feeling for when the tires were about to let go. The one time that I couldn't stop at all, I still was able to maintain better control with manual brake application than the ABS gave me. Still ended up several hundred yards past the house before the road leveled out enough to get stopped.
I've been missing living up there, but this just reminded me why we moved -- I'm in the process of teaching my daughter to drive and I'm SO glad I don't have to worry about here driving on the mountain as a new driver.
Wow, that's very troubling to hear about but happy you mentioned it.
I guess I had assumed that ALL automatic braking systems were equal, which I see now was a bad assumption. I have to wonder now if there might have been a recall on that vehicle, or could it just be a faulty ABS module.
On my Volvo, there is way to turn the ABS system off although they say they don't recommend it. I do have a problem with it now though the module needs to be removed and all the connectors resoldered as the connector pins are known to come loose from the PC board as time goes on, and it's an antique now (I can show it at car shows ha ha).
On the Buick there is no way to turn it off, so hopefully I don't run into any problems because of that.
From what I remember from the past, without ABS you are supposed to pump the brakes on and off when on a slick road. When I drive in winter, I take mostly back roads and drive much slower than normal anyway, and make a habit of periodically testing the road surface by trying to stop when there are no cars behind me.
