Hello
Got 100 amp hour ,12 volts AGM battery.
Will this increase running time of of 12 volts battery, using LED 12 volts ,10 watts led.
if I get buck converter board to drop the 12 volts battery volts to 5 volt,
and hookup Boost converter board to buck converter board to boost the 5 volts to 12 volts will this extend the battery running time longer since the battery only put out 5 volts and boost converter is creating 7 volts to make total 12 volts .
Will this work?
mrel
Will this work?
mrel
