Thank you for the feed back, this stuff all looks good on paper till you get down to play with it.It depends a lot on the design of the buck converter. A converter that uses "current mode" control (i.e. an inner loop that controls the current in the switch & inductor with a voltage control outer loop) does a very good job of rejecting input ripple, even if the voltage control loop isn't very good.
Even where current mode control isn't used, the voltage error amplifier generally has very high gain at the input ripple frequency, so it is able to reject a large amount of ripple. If the bandwidth of the error amp has been rolled off to a low frequency for some reason, then you can get ripple on the input showing up on the output. Of greater concern with low bandwidth is overshoot and undershoot of the output voltage if the load is abruptly decreased or increased - poor dynamic respsonse.
It isn't too common anymore, but occasionally you see "feedforward" added to a switcher. The purpose of this is to directly change the duty cycle in inverse proportion to the change in input voltage. Perfectly tweaked, feedforward can make the switcher almost totally reject variation in the input voltage. Current mode control is actually effectively a feedforward method.
