Will this Circuit works
WBahn
Joined Mar 31, 2012
33,209
Please confirm below attached circuit works or not ?
3.3V From controller.
Thanks,
Ashok
You need to better define what it means for it to work?
If, by "work", you mean that a signal that goes from 0 V to 3.3 V will have change the amount of current going through the LED, then it will work.
But if, by "work", you mean that it will get enough current through the LED in order for it to be perceptibly lit, you haven't given us enough information.
Assuming your MOSFET switch works ideally and you get the full 12 V across the LED/resistor and assuming your LED drops 2 V, then your current is going to be about 830 μA. Is that enough to light up the LED well enough for your purposes? We have no way of even estimating that since some LEDs work will at currents even less than that while many require significantly more.
WBahn
Joined Mar 31, 2012
33,209
+1. Extreme over design.
The circuit will work, but anyone looking at it will be wondering why that MOSFET was chosen.
It has a threshold voltage that can be as high as 2.5 V. The microcontroller output can probably be as low as about 3.0 V due to supply tolerance (and even lower and meet logic family specs). That doesn't give a lot of overdrive, but this transistor doesn't need much to get the kind of currents involved here to flow. Also, it looks like the input capacitance is pretty hefty at around 10 nF. That might come into play if it needs to switch quickly.
ashokchandra
Joined May 13, 2018
37
I Designed this circuit for to confirm the 12v Available or not.
Thanks,
Ashok
WBahn
Joined Mar 31, 2012
33,209
Thanks,
Ashok
That doesn't help much.
HOW does this circuit confirm that 12 V is available? By lighting up the LED? If so, then everything I said still applies. You are going to have less than a milliamp flowing in the LED. Is that enough to make it light up sufficiently in order for you to determine that 12 V is available?
ScottWang
Joined Aug 23, 2012
7,505
For your application then you can try 2N7000, when the Vgs=3.3V then the Ids could provides >80mA (If the figure 5 on page 5 is correct).
Led = 2V/20mA, R = 610Ω(16.4mA), Vds = Ids*Rds = 16.4mA * 1.2Ω ≅ 0.020V when Vgs ≥ 3V.
Led = 3V/20mA, R = 560Ω(16mA), Vds = Ids*Rds = 16.mA * 1.2Ω ≅ 0.0192V when Vgs ≥ 3V.
ericgibbs
Joined Jan 29, 2010
21,573
hi ashok,
If the LED is to indicate the state of the 12V line, why not just a 1k in series with an LED.?
What is the purpose of the MOSFET, there is no obvious feedback from the FET , other than the observers eye.??
If the MCU output pin is not at 3.3V ie: 0v , would that mean the 12V line is 0v.???
E
ScottWang
Joined Aug 23, 2012
7,505
You still didn't say that why you want to using the MOSFET to drive the LED, if only to do the indicator, maybe you can only use the LED with a small resistor and connected to the digital output of uC.
