Will my circuit work?
Pti_craig
Joined Aug 26, 2015
4
I'm new to electronics so as much help as possible please.
In diagram is two 12v dc batteries, a 6 pin toggle switch (on- off-on) and a socket to a motor.
I believe the way this is rigged up I will be running
* - one 12v battery in the off position
* - two 12v batteries in series to make 24v in position 1
* - and two 12v batteries parallel to make 12v in position 2.
Will this work? Please excuse the basic picture
dl324
Joined Mar 30, 2015
18,326
Position 2 puts the batteries in series, but taking the output from the common terminals means you'll always have 12V at the plug. In position 1, it's both batteries in parallel as you wanted.
I'd do it like this:
Pti_craig
Joined Aug 26, 2015
4
Took me 3 hours to work that out with easily 50 drawing, so glad it will work. I will also take your way into account.
Thank you for your help
Hypatia's Protege
Joined Mar 1, 2015
3,228
FWIW: You will spare yourself much time and 'agro' via adoption of schematic (as opposed to pictorial) representation -- Schematics illustrate the circuit -- whereas layout drawings, etc... show only that -- layout...
With constructive intent
HP:)
Sensacell
Joined Jun 19, 2012
3,785
Depending on the type of battery... connecting them in parallel can be problematic, they will "fight" if the terminal voltages are not exactly the same.
