Wifi Access Point Help
LEEWOOD
Joined Sep 9, 2019
6
I am looking for a module pcb that i can use as a wifi access point must be power over ethernet with rj45 connection for input do you have anything or can you recomend anything, thanks Lee
LesJones
Joined Jan 8, 2017
4,511
Some Wifi routers can be configured to work as an access point. I have done this using a Linksys WAG200G router. If you have a spare router try Googling using that model router as an access point. (That is how I found out how to configure it.)
Les.
djsfantasi
Joined Apr 11, 2010
9,237
Take a look at the:
MakerFocus ESP8266 ESP-01 Serial Wireless WiFi Transceiver Receiver Module“
This module can be configured as a wireless access point. That’s the Amazon description, so you should be able to find it on Amazon.com with the description.
