Why won't my 555 strober circuit work?
resawlin
Joined Dec 8, 2024
9
I don't know what is the issue. It was working fine with the red LED with a 9V battery but when I connected it to my car, it just kept strobing without a waiting period. I removed the circuit with the bulb from the car. I will get myself a 12V 2A adapter and test it as it is connected to my car. But I don't know what is wrong with it. I don't know what to test it. Maybe I change the resistors and capacitors with different values. Please let me know if you think something is wrong with my setup. I will specify the materials here for clarification;
  • First 555
  • resistors are 100k
  • capacitor is 22uF
  • Second 555
  • resistors are 4.7k
  • capacitor is 10uF Output pin of second 555 is connected to GATE of an IRFZ44N with a 220 ohm resistor in series. The bleeder resistor between SOURCE and GATE is 10k.
This is the Falstad link of my design
Terminals on right are from top to bottom for the image below;
  1. Vcc of the circuit
  2. GND of the circuit
  3. Drain of the MOSFET
  1. Drain of the MOSFET
  3. Vcc of the circuit
resawlin
Joined Dec 8, 2024
9
  • First 555
  • capacitor is 22uF
  • Second 555
I am adding a circuit diagram I just draw from Fusion on request.
It was working when Vcc was 9V and with the LED but when I connected it to 12V (car) and replaced the LED and its resistor with the back fog lamp of my car, it started to stoble continiously.
28,626
I guess that is an interesting problem. Unfortunately I have no idea as to what a Falstad diagram is, or what it tells me.
I have not yet adequately evaluated the circuit schematics.
And the actual complaint is a bit confusing to me.
resawlin
Joined Dec 8, 2024
9
It should work like this. Instead it is constantly flashing. As for the Falstad diagram, I don't think it is a legit diagram. It is a website that simulates your circuit with time. I drew this circuit there first then I added a Fusion diagram in the comments. They are both identical.
35,321
I think you are talking about that connects 100k resistor with pin-2. What is wrong with it?
My post was meant to be tongue-in-cheek!
Here is what I would do differently:
1. Use 30 AWG wire wrap wire.
2. Use different colours to help identify wire function.
3. Don't put more than one lead or wire in a hole.
4. Use Vero strip board (Veroboard) instead of single pad solder points.
Even this is better than what you are using.
Before building a project on a circuit board, you should test it out first using a solderless prototyping board.
28,626
I suggest adding 0.1 mfd capacitors across the input power connections (pins 1 and 8) of each 555 IC. The symptom is power fluctuations causing unwanted coupling between the two ICs.
35,321
Similar to what MisterBill says, I would suggest adding 1-10μF across pin-1 and pin-8 of both NE555 ICs and 47-100μF across the power supply rails where they enter the board.
Homebrew1964 Analog & Mixed-Signal Design 26
Similar threads
My Lamp won't light?
