why the voltage and currents are not complex?
thatsmessedup
Joined Feb 15, 2018
59
Why in the transmission line equations for voltage and current, they are not indicated as complex with a line above like they do with other complex quantities?
WBahn
Joined Mar 31, 2012
33,203
Usually by the time someone is dealing with transmission lines they are past the point of needing the crutch of a visual indicator for when something is complex and when it's not. Dispensing with those indicators declutters the diagrams and the work considerably.
MrAl
Joined Jun 17, 2014
13,797
This can actually be found in many cases.
For another example you will find widespread use of notations like V(s), H(s), T(s), etc., where lower case 's' is a complex quantity but is not explicitly stated as such.
thatsmessedup
Joined Feb 15, 2018
59
Thank you.
