Can IR Sensor TCRT1000 and TCRT5000 operate at 12V?
DonBradman
Joined Mar 30, 2023
40
I asked chat GPT, and it said TCRT1000 and TCRT5000 are not suited for ops above 5V. But interestingly I have read a research paper where TCRT1000 has been used at 9V. I would like help decoding these datasheets and understanding whether its safe to use these sensors at 12V, I don't really trust Chatgpt, its lies ten times in a line. I am mainly interested in powering the Phototransistor via 12V, even if the IR lamp is powered via 5V.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Why would it be necessary to observe 5v only?
As long as the relative current values/limits are observed, there should be no problem?
I don't see the limit on the sheet?
DonBradman
Joined Mar 30, 2023
40
Figured it out through help at another forum, its 32V for TCRT1000 and 70V for TCRT5000. Need to watch value under Vceo in datasheets.
LesJones
Joined Jan 8, 2017
4,544
The 5 volt maximum voltage rating is with the polarity reversed to that in normal operation.
In normal operation the collector is connected to positive and the emitter to negative. The 5 volts rating is if the emitter is positive and the collector negative.
Les.
