Why is the unity buffer behaving differently to different AC inputs?
supermankid
Joined May 26, 2013
56
I am having some difficulty in understanding this circuit.I was reading about the unity gain discrete transistor circuit.I tried to simulate the example circuit and see the result for different waves.
For a pure sine wave the circuit is acting as a unity gain buffer. But for a triangular wave, there is some kind of offset in the output. Could someone please explain why it is behaving differently in the triangular wave input?
Both the inputs are essentially AC input so I was expecting similar results on both the circuit.
Circuit
AlbertHall
Joined Jun 4, 2014
12,625
You have a 50 second time constant on the output, 100uF/500k. Therefore it will take about 500 seconds for the output DC level to settle to its final value. The sine wave starts at 0V while the triangle starts at +5V and that's why they give different results. If you run the simulation over 500 seconds then the triangle wave will settle to zero DC offset. To make it quicker, try changing the 500k to 2k (200mS time constant) and watching the result over 2 seconds.
