Why double snubber in schematic?
mariosergio
Joined Feb 23, 2018
23
The attached picture shows a circuit from the Motorola's datasheet for the MOC3021 optocoupler.
In the circuit there are 2 snubber networks, and the description says it's one for the triac and one for the MOC3021. But it seems like they are connected in parallel. From the 'LOAD' to 'HOT' you pass a capacitor and then a resistor.. So why have two snubber? The "0.01uF+39R" seems unnecessary to me.
Thanks for the help!
Ian0
Joined Aug 7, 2020
13,230
It will work with no snubber in almost all applications.
The 39Ω/10nF snubber might be needed occasionally, especially if you use old (not "snubberless" triacs)
mariosergio
Joined Feb 23, 2018
23
Yes.. the plan is to use old regular triacs.. snubberless is hard to find over here.
So, should I keep the 39Ω/10nF snubber, even with the 470Ω/50nF?? btw, I'm changing 50nF to 47nF, and the 39Ω to 60Ω
thanks for the reply
