Hello friends.
There's a circuit I'm trying to build but it seems it would require enough opamps to function to justify just using an MCU instead.
I want to measure the voltage differential across two different resistors in series and ensure they are sharing equal voltage regardless of their resistance differences.
I also need to reach this voltage equalization through the use of a lowside current source.
So in essence I want to tell the MCU to keep X volts across both resistors and have it adjust the current source until that point is reached.
I'm assuming I would have 3 internal ADCs measure the voltage across the 2 resistors in series and use a filter at the PWM output to feed the positive input of an opamp based variable current source.
Then write code to tell the MCU to sweep its output until both of the feedback inputs equal the desired voltage.
Any advice? I haven't built my own MCU circuit before and I'm a little rusty on code. I just want the cheapest part for the job.
Thanks.
Thanks.
