where can find a kind of Jumper wires
LAOADAM
Joined Nov 21, 2018
956
I bought many Jumper wires, all feel stiff, not flexible.
where can find some better one? flexible, durable both for the pin and wire?
Adam
SamR
Joined Mar 19, 2019
5,542
Breadboard jumpers or patch cables? Since you said stiff, I assume breadboard. I've never seen stranded breadboard jumpers but you could make them with No. 22 stranded wire and header pins. Easier if you have the proper pin crimper.
Irving
Joined Jan 30, 2016
5,195
But beware the cheap 'Dupont' copies whose pins are so soft they break off in the breadboard almost as soon as you start using them... (and the female ones grip only once).
The pin-jumpers at the middle & bottom of this breadboard with the circular fitting are the ones I fnd most robust. The'dupont' crimped style with a square cover at the top right are the typical shape of the cheap ones
SamR
Joined Mar 19, 2019
5,542
I use both Dupont wires that are sort of flexible although still solid wire and solid stripped w/o pins No. 22 wire. In addition to the assortment of stripped solid wire kit (which has mostly sizes I don't use) I also fabbed more of my basic needed jumpers.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
SamR
Joined Mar 19, 2019
5,542
The problem I have with the box kit on top is I never use most of the longer wires and fabbed more of the shorter wires. 2-6 spaces.
These have a few longer wires that come in handy. 2-3 bundles will do ya.
I like to use both the fixed wires and jumpers as needed. Having a bunch of jumpers waving in the air acting like antennas is asking for signal problems.
LAOADAM
Joined Nov 21, 2018
956
Thank you.
