When using multiple step-down converters with a single power source, how much input voltage is required?
Jon Chandler
Joined Jun 12, 2008
1,646
Good suggestion for use with 20V signals, but probably not for 28V. The mini360's maximum input voltage is just 23V.
My apologies. I missed that detail, but as I explained, 28 volt USB PD supplies aren't that common, and would be more expensive if purchasing one in required. If 15 volts provides enough overhead for the DC-DC converter, it will be the most-acvailable power supply.
aaaaaaaaaaaaaaaaa
Joined Jan 7, 2026
9
Thanks again. If 20V works then that's great.
In another corner of the internet, somebody told me this: "If you were to try to pull both 12v and 5v from a 20v supply, you would very likely have issues with the power draw."
Is that true? This claim that 20V does not provide sufficient headroom to power the +12V, -12V and +5V rails together is what I've been trying to verify this whole time. I'm still not sure if it's accurate or misleading.
Jon Chandler
Joined Jun 12, 2008
1,646
A 60 watt PD supplies 3 amps at 20 volts.
Per your specs some pages back:
+12v @ 1 amp = 12 watts
–12v @ 700mA = 8.4 watts
5V @ 400 mA = 2 watts
That's a total of 22.4 watts. Let's say the worst case efficiency is 70% (likely closer to 80%).
22.4 watts /0.7 = 32 watts considering efficiency. A 60 watt [20 volt] PD supply will be coasting along.
A 45 watt [15 volt] PD supply shouldn't be over-taxed at ⅔ rated load.
