when an induction motor connected to a constant 3-phase source slows down from its rated speed.
xizhouxiang
Joined Mar 23, 2017
when an induction motor connected to a constant 3-phase source slows down from its rated speed. what happens to the stator current amplitude and frequency? the magnetizing flux?
MaxHeadRoom
Joined Jul 18, 2013
30,807
What is slowing it down? load?
A 3ph induction motor at switch on represents a 3ph transformer with shorted secondaries.
The current in the rotor is dependent on the relationship between the rotating stator field and the rpm of the rotor, as the rpm of the rotor approaches synchronism, (which it can never reach), the current diminishes.
The rpm of the rotor off load usually achieves the rotation rate of the stator field minus 4 or 5 cycles (AKA slip frequency).
Max.
