What's this thing and how do I remove it?
jotwerde
Joined Jul 19, 2018
10
I'm trying to fix a desk lamp but can't remove the cable because this round thing is holding it in place.
Is there a proper way to remove it without destroying it (which I did with the last one I found)?
Also, how's it called? I tried google image searching this pic without success.
AlbertHall
Joined Jun 4, 2014
12,624
It's difficult to see in the picture but if that grey bit around the wire is in two pieces then squeeze the two parts together with pliers or similar. This will release the grey bit from the casing and then the two parts will separate releasing the wire.
jotwerde
Joined Jul 19, 2018
10
Thank you all! Was able to remove it, though it was a bit hard, with my regular pliers slipping off the strain relief.
jpanhalt
Joined Jan 18, 2008
11,087
I try to remove them from the inside, if accessible. That way, you do not bugger up the part that shows. Same process of squeeze, except push instead of pull. You may need to rotate it to get your pliers on the wings/inside stops that need to be compressed.
