What's this circuit is used for?
DickCappels
Joined Aug 21, 2008
10,661
It looks a little bit like a sample-and-hold circuit. The voltage across the 2.2 nf capacitor as long as the current sources are powered by the + and - drive signals and when those signals are removed the capacitor (tends to) maintain the same voltage until the next time to take a sample.
DickCappels
Joined Aug 21, 2008
10,661
Because by limiting the charging current to a constant value the output changes linearly with time, in other at a rate of some number of volts per second, a opposed to the logarithmic curve of an RC circuit. I think this is common in industrial controls.
evandro bubiak
Joined Aug 4, 2015
12
Thank you!!! You opened my eyes!
Ramussons
Joined May 3, 2013
1,568
My memory tells me It is an Analog Switch that uses a Diode Bridge Network.
When the diodes are Forward biased (conducting state), signals from the Left are transmitted to the Right.
When the Diodes are Reverse Biased, the transmission is blocked.
The 2 BJT's form a Constant Current Source.
