What would be the best recommended replacement for a BJT
dl324
Joined Mar 30, 2015
18,405
Insufficient information.
  1. What is the switching frequency of the intended circuit?
  2. What is the supply voltage?
  3. What current gain do you need?
A schematic would be helpful.
gkmaia
Joined Dec 22, 2018
34
Thanks for the reply. It is to replace Q104 and Q101. The original 1409 was a 100mhz with current gain between 70 to 280 @2v1A. Supply is 6.5v. That is what I know about the circuit.
Ylli
Joined Nov 13, 2015
1,092
Q101 is operating at DC, and Q104 probably at less than 100 KHz. You don't need a transistor that is good to 100's of MHz.
