What would be a suitable transformer for this circuit?
RoabeArt
Joined Apr 6, 2023
As a kid I had one of those electronic project kits that Radio Shack would sell. One particular circuit I really liked was the "Electronic Siren" and I kind of want to recreate it to see if it's sounds as good as I remember it. It was basically a sweep oscillator(?) that when you pressed the key, the siren would start off and wind up to a peak frequency, then wind back down and eventually stop when the key was released.
I have a good inkling of the components needed but I'm stuck on what transformer to use. Based on the parts list in the manual, it's center-tapped with a 900Ω input and an 8Ω output (the manual describes it as "900 CT, 8 ohm"). I'm trying to find one online but I keep finding large power transformers. Would a 4.5v source be enough to drive one of those?
See attachment...
RoabeArt
Joined Apr 6, 2023
Thanks for your responses everyone. This is this the first time I built a circuit where I'd needed a transformer (or at least a transformer that wasn't in a presupplied kit) so I'm treading in unfamiliar territory.
Dodgydave
Joined Jun 22, 2012
11,395
See attachment...
You can replicate this with a 555 timer chip, and an output transistor..
MaxHeadRoom
Joined Jul 18, 2013
30,796
In my younger days when transistor radio's first appeared on the scene, a Company soon got into the business of putting together a kit, I would pick them up and put together for family and friends, they got a cheap radio, cheaper than off the shelf, and I got beer money! :p
AnalogKid
Joined Aug 1, 2013
12,264
PeteHL
Joined Dec 17, 2014
594
My thought was that you might be able to substitute power audio amplifier LM386 for the transformer. But I see that the supply voltage is connected to the center tap 51 of the transformer's primary, while the other two taps of the primary connect to the base and collector of the 2nd transistor. Knowing very little about transistor circuits, I can't say what is accomplished by these connections to the primary winding.
Except for LM386N-4, the minimum supply voltage for the amp is 4V.
-Pete
-Pete
The base connect side of the CT primary provides a 180 phase shift, that combined with the common emitter transformer driver transistor 180 phase shift, it gives the positive feedback needed for circuit oscillation.
28,176
-Pete
The transformer is a very much integral part of the circuit. It provides the feedback to make the circuit oscillate. So there is no way the posted circuit can possibly use a 555 or am LM386 as substitutes.
ALSO, transformers are still used, but not usually for audio amplifier outputs. So a low-power transformer, 200 to 500 ohms primary impedance, center tapped, to 8 ohms, or 10 ohms secondary impedance, should work.
A NOTE TO ALL: the TS did not ask for a redesign that would be entirely different!!
