Judging from the surface appearance, it looks like it may be braided or stranded wire. For braided, you can use the fine wire used in shielded cables (if copper) or strip some flexible insulated wire. If you use uninsulated wire, you may want to secure it with a dab of adhesive, like Goop(E6000), hot glue, or electronic-safe (non-acidic) silicone.
