What will desolve PLA plastic?
Wendy
Joined Mar 24, 2008
23,857
Now and then I want to dissolve PLA plastic from a magnet I am trying to recover. Acetone softens things up but not very well for PLA. Any ideas of reasonably safe chemicals they can dissolve PLA?
Wendy
Joined Mar 24, 2008
23,857
I saw this chemical during a previous search. The MDSS sheet reads like a horror novel.In the old days I would put on gloves an go on and use it. but since gloves are not something I could put on, it's a no go.
35,245
Dichloromethane (DCM) works as a good glue for bonding PLA as well as Perspex, Plexiglas, (PMMA).
It melts plastic and evaporates quickly, causing the fractured pieces to bond.
The trick is to hold together the parts to be joined or mended. Use a fine needle syringe to apply drops of DCM to the crack. The liquid will quickly seep into the crack by capillary action. You don't need a lot of DCM. Just one drop will do for a small crack.
