Plastic cases for Nucleo boards
Futurist
Joined Apr 8, 2025
950
I read that the dimensions and so on of the Nucleo-64 boards, are "compatible with" Arduino stuff, that a case that accepts a "standard" Arduino board can also house a Nucleo board but can't really find anything that's clear on the issue.
I'd be interested in hearing from others about this.
Futurist
Joined Apr 8, 2025
950
No, that's not much help unfortunately.
The Nucleo-64 boards are all 70mm x 82 whereas Arduino Uno boards are 56mm x 69mm.
That doesn't sound compatible really, and the Uno has four holes and the Nucleo has three and although the holes (appear) are aligned OK the Uno board is shorter and so a case made for that board could be too small for a Nucleo.
There are plenty of people sharing 3D printer designs for making a perfect Nucleo case but I don't have a 3D printer and just want to buy a case.
Maybe there's a Chinese company I can find...
Strange there are no commercial boxes.
I've used jlcpcb in the past to make enclosures from STL files. I'm sure there are many other vendors.
