What voltage would you expect in the following diagrams?
PeterPiper
Joined Aug 23, 2017
Figure 1 - What voltage if I measure between +15 and -15 and what polarity?output.jpg
Figure 2 - What voltage if I measure between +15 and -15 and what polarity?output2.jpg
Reloadron
Joined Jan 15, 2015
7,952
30 volts in either case and polarity read will depend on on which line the meter probes are placed. Since you are measuring between two defined points the Ground symbol in the second image means nothing. It's a matter of point of reference for your metering device.
Ron
35,198
If you ground either +15 or -15 in Figure 2, you are creating a short circuit. If the power supply is not short circuit protected then expect to see sparks fly.
