TLC555 There is Voltage peak at the beginning
Codearius
Joined Aug 25, 2026
5
I don't understand how i can eliminate the voltage peak at startup. This Peak causes the output of the first TLC55 to get high. But i just want to trigger the switch not the startup? Does this happen only in LTSpice?Screenshot 2026-08-25 140823.pngView attachment 3707401787660648986.png
sghioto
Joined Dec 31, 2017
8,760
Maybe, try this:
Connect a 1uf cap from pin4 to ground and a 100K resistor from pin4 to VDC.
BTW, you can make that circuit with a single TLC555.
38,932
Try connecting C4 to VDC instead of ground.
What is the purpose of U1?
It does not seem to be needed, as U2 can be triggered directly from S1.
Codearius
Joined Aug 25, 2026
5
The U1 is triggered by a constant or fluctuatingsignal the U2 is giving a 1 second impulse
Maybe, try this:
doesn't change anything
Hi Code
Please post your LTS asc file.
E
Thank you for the advise. I'm not so familiar with LT what shows the asc what cannot be seen on the Screenshot? How can i work with the asc file?
ericgibbs
Joined Jan 29, 2010
21,637
hi Code,
This is what I see in a LTSpice simulation.
What problem do you see in your simulation??
Note I have added measure point labels p1,p2,3.
Codearius
Joined Aug 25, 2026
5
I do not understand why the trigger U2 at measure point p2 takes so long to get high in the beginning this causes p3 to get high. I want the U1 out to trigger the U2 and not the start. Does it really takes too long to get the U2 trigger High (p4) at startup and the U2 is setting out (p3)high? How can i change this behaviour?Screenshot 2026-08-26 115905.png
ericgibbs
Joined Jan 29, 2010
21,637
Hi Code,
Download and run the asc file I posted in post #9
You ask:
The PULSE is only operating the S1 switch, there is no pull up resistor !
Look at my modified circuit.
E
38,932
Circuit using one 555 with no startup glitches:
Note the startup transient option which ramps up VDC from zero at the start of the simulation to simulate a normal application of power.
Codearius
Joined Aug 25, 2026
5
Thank you very much for all you teached me. You are absolutly right i just need one TLC. The RST to 10kOhme VDC and 10uF Cap to Ground and the tlc model with the startup Sorry that i listened too late.
28,529
FINALLY, in post #14, we see power and common connected to the devices. Startup operation is seldom the same as steady-state operation.
What would have been very useful is a description of the desired output function in response to the planned input trigger.
I suffer the handicap of not being able to see what is in other people's minds until they speak it or write it out. Fortunately, I can read much better than I can hear.
