HiThe diode and 1K resistor look to be configured as flyback for the coil. Unless the diode anode goes more positive than the cathode the diode will never be forward biased. What exactly is the coil? The inductor (coil) and capacitor form a series LC circuit. The coil inductance is unknown? If the cap were not in series with the coil and the transistor was maybe an old 2N3055 I would have guessed an ignition coil test circuit but the cap is in there forming a series LC circuit.
Ron
HiDoesn't seem to do much at all other than charge a capacitor
I have found it inside laser diode I just want to understand itWhat are you wanting to do with it?
Well then the 2n3904 is a common switching NPN transistor with a max current of about 200 mA if I recall correctly. The 103 labeled is a ceramic disk of 10,000 pF. I don't see where the 1N4148 will ever be forward biased? Less knowing the inductor value I am not sure what the circuit is supposed to do.Hi
Thanks for your response the transistor 2n 3904
And the coil is not critical value
If you don't know what the circuit is, what it does, or how it works, how do you know that the value of the coil isn't critical?Hi
I am asking to get knowledge not get evaluation from youIf you don't know what the circuit is, what it does, or how it works, how do you know that the value of the coil isn't critical?
Yes it's correct drawingHave you drawn it correctly?
Where does the circuit shown connect to the laser diode semiconductor section terminals?I have found it inside laser diode
I don't know where the laser diode terminal's connected It is 5 volt laser diode but i think one with positive terminal of the coil on main dc line and the other to the transistor emitter terminal I think the circuit change the current of the laser diode or making sort of modulationWhere does the circuit shown connect to the laser diode semiconductor section terminals?
How does that 103 capacitor ever discharge?Hi all
The ic is 555 timer generate maximum 1 khz square wave
The diode is 1n4148
The combination of the Dodie rlc what and how works
Thanks in advance
The capacitor and series inductor "ring" at their LC frequency with the voltage fading each time the 555 turns off the transistor.How does that 103 capacitor ever discharge?
Correct. If the laser diode has no current limiting then it quickly burns out.Somehow, I doubt that the circuit is correct as drawn. There is no DC path through the transistor. But then we don’t know where the laser diode is connected.
The laser diode has built In current resistor it's working on 5 volt and circuit works on 5 voltCorrect. If the laser diode has no current limiting then it quickly burns out.
How is it connected to the circuit you posted? Without it, the circuit makes no sense.The laser diode has built In current resistor it's working on 5 volt and circuit works on 5 volt
| F | Basic Amp Circuit Question | Homework Help | 2 | |
Capacitor discharge circuit in modern multimeter | General Electronics Chat | 31 | |
| L | Did you ever make a circuit and gift to your loved one? | Off-Topic | 11 | |
| A | Help me Battery current limiting circuit with UC3842 | Analog & Mixed-Signal Design | 19 | |
| M | Analogue SPDT Circuit | Analog & Mixed-Signal Design | 30 |
