Okay so from what I've gathered, the tl082 cannot supply much current, (5ma)? Can I drive some small to-92 bjts in a darlington config and then drive the TIP pair with arounf 110ma? Is 110ma input for the TIP transistors their limit? I probly wouldn't need the op amp huh? Also, the slew rate may not be high enough on cheap to-92 bjts?
Why would i need a high voltage drive for higher power output when the power out depends on the rail supply to the output transistors(the tip out transistors)
