what sort of mosfet or igbt can handle this
Discussion in 'Power Electronics' started by pager48, May 13, 2019.
  1. pager48
    Nov 25, 2018
    304
  2. ronv
    Nov 12, 2008
    3,692
    2,837
  3. pager48
    Nov 25, 2018
    304
    High voltage MOSFETS cost much more than IGTBs for similar voltage.
  4. shortbus
    Sep 30, 2009
    6,408
    3,736
    You'll never get far asking him questions. Personal experience.
    ronv likes this.
  5. ronv
    Nov 12, 2008
    3,692
    2,837
    pager48 likes this.
  6. ian field
    Oct 27, 2012
    6,543
    1,194
    IGBTs are slow because the output structure is an emitter follower.
    pager48 likes this.
  7. pager48
    Nov 25, 2018
    304
    That is a decent part but going obsolete not even found on digikey.
    From the switching waveforms whats the minimum voltage and current curves needed in SOA for a device?
  8. ronv
    Nov 12, 2008
    3,692
    2,837
    pager48 likes this.
  9. pager48
    Nov 25, 2018
    304
  10. ronv
    Nov 12, 2008
    3,692
    2,837
    DC.
    You IBGT is much hotter due to it's Vce drop.
    pager48 likes this.
  11. pager48
    Nov 25, 2018
    304
    IGBTs do get much hotter but they are less expensive at higher voltages past the max voltage of the part you liked which is a very decent part. I should obtain it since its going obsolete and its cost is likely going decrease.
    Wouldn't the required SOA be only 7amps for about 20uS?
  12. ronv
    Nov 12, 2008
    3,692
    2,837
    All I know from your picture is that the maximum current is 7 amps and the blocking voltage is 430 volts.
    I'm sure you know more since it's your circuit.
    pager48 likes this.
