The sound of sorting algorithms
Ya’akov
Joined Jan 27, 2019
10,350
When I was programming my TRS-80, as a teenager, I would put an AM radio nearby and use the sound for troubleshooting. It was surprisingly helpful.
38,909
When I went to college in ancient times (the early 60's), the school had a home-built vacuum-tube computer containing about 15,000 vacuum tubes (and took about 15kW to operate!).
(I think it was programmed directly in machine language).
They had added some sort of A/D converter connected to a speaker and that looked at the data bus to monitor computer operation.
The bus rate was slow enough (I think the main clock was 100kHz) so that it gave a curious, random sing-song output when operating normally, but if the song pattern started noticeable repeating, it meant it was caught in a loop without an exit.
Ya’akov
Joined Jan 27, 2019
10,350
That was one of the things I used the radio for! The clock on the Z80 CPU was 1.77MHz, so the AM broadcast band receiver was a perfect monitor. You could could, with practice, also get a sense of what parts of your program were executing.
schmitt trigger
Joined Jul 12, 2010
2,273
Y:
If I recall correctly, the Z80s instruction’s execution time was a sub-multiple of the clock speed. That would put the execution frequency right smack in the middle of the AM band.
Ya’akov
Joined Jan 27, 2019
10,350
Y:
Yes, and you could tune for how it sounded. It would tend to emphasize some instructions more than others depending on that.
